foam/triple foam gun kit
Martins
Wondering if anyone has a link to a foam gun kit. i want to move my presoak off my high pressure manifold since i think my cv are part of my on going problem im trying to fix. I cant seem to find a kit on kleenrite to put the gun in the bay. basically i only need the gun, hose and mount for the connection point to the trough.
Thanks all!
Martins
I think the parts you need are on this pricing sheet.
He has everything you need I do believe.
Thanks! i have a bunch of their stuff but i didnt see it on kleen rites site. maybe ill give them a call and order directly. Also where in MI are you located. my wash is in Clio.
I use this gun because the metal inside is all stainless. The steel ones usually rust apart after a couple years. I use a 2540 tip with it.
Rookie68
No Problem. I am in Muskegon, MI.
Ryancross11
I change my presoak/ tire/ motor off my high pressure to a “triple foam” setup. People love it. They’ll spend 2+ min just applying it.
jack954
i as well. it was a very easy, low cost, effective upgrade!
