On my WW Razor I have the Foam N Flow with the 4 injector manifold. It worked flawlessly for almost a year. I noticed that my new bucket of Foamy Simoniz wax is thinner than it use to be. The Simoniz Foamy hot wax use to be really really thick. I was sent a new bucket. I swapped the old bucket out with the new one. I used the tips they recommended they said start off with light blue and then go smaller to dial it in and have your air pressure set between 30 - 45 psi. After adjusting the air pressure within that range and up to 50 psi no change and no foam just yellow water rain effect.
Has anyone else ran into this issue? How do you have your Foam N Flow setup? I am afraid to keep playing with it without having a place to start because this stuff isn't cheap to be running down the drain.
