owinborne67
Know there have been many threads with a variation of this problem but none of them seemed to match mine so thought I'd create a new one
Root problem is as it says - when the foam brushes have been sitting for a while they'll often blow just air, no foam. Further details:
- I have the regulators set so when foaming the air pressure is ~10 - 12 psi under liquid pressure - about 30 psi liquid pressure when foaming.
- When foam brush is selected but it isn't foaming, liquid pressure will read very high - like 70 psi.
- Once they start foaming the foam is very good - lots of volume, nice consistency and color, and all bays will start foaming with enough fiddling.
- Sometimes briefly kinking the foam hose then unkinking it will start the foam.
- Sometimes fiddling with the pressure regulators will suddenly get the foam started.
- If a bay is blowing air, starting a foam brush that is foaming in a different bay will start the foam in the one that was blowing air.
