Foam Brush will not quit dripping
Pat Quam
My foam brush is dripping continuously. What can I do to fix this issue?
You have a valve issue. You probably have some debris under the valve seat. Turn off the system and remove the valve stem from the valve that’s leaking and check the inside for debris or erosion of the valve seat.
