shineanddrivevulcan@gmail
what do you consider at your car wash to be the best air to chemical PSI for a foam brush?
What do you look for in foam, do you prefer lots of foam or just a little.
Background, I moved over from a generic white foam soap that I had a hard time making foam with. Picked up a turtle wax product and was astonished at the amount of foam you can produce with it. Have it currently set so when you do a full size truck the foam is still slowly going down the side of the vehicle after you do the whole vehicle.
what's your opinion as each car washI have visited is drastically different.
