Foam Brush air purge using existing manifold?
Bubbles Galore
I have a foam brush purge system that works fairly well, but I would like to air purge prior to injecting the antifreeze solution.I was hoping to just use a delay on break timer to keep the air solenoid open, but I am not having much luck finding anything like that.
I know a plc or smartrelay would work substantially better, but I don't want to spend a lot since the system already works fairly well, but I would like to reduce the amount of required solution by having the line clear.
Any ideas?
