Twodose
What settings for Air and Liquid on a Foam Brush System.
And are you using foam brush generators?
I just mix in air with the foam brush soap...soap pump set at about 40psi and the air mixed in is set about 5 psi less.What settings for Air and Liquid on a Foam Brush System.
Coleman has these as strainers in their shampooers. HAve had them fail over the years. A good reason not to have them in the trough.This is what I use for "foamers".
It's a Hypro 3350-0082 inline strainer...1/4" FNPT or 1/2" MNPT threads on each end. They work great!
Or, make your own from PVC pipe and fittings, stuffed with pieces of plastic pot scrubber (Chore Boy) or 3M scrubber.
Another reason not to have them, particularly in the trough.Be sure that you make them so you can take them apart, they will crud up and you will need to clean them out.
I was just curious as to what setting's others were using on the FB for air and liquid, and if they were using FB generators.After reading thru these post again I guess I will ask...what problem are you trying to solve?
