I know this has probably been discussed on here numerous times but I can't find the info I need. Our truck bay was added on to our wash after it was built. It has a separate stand alone Paloma PH12 tankless water heater and a Grundfos pump. I have fought this thing all year so far. First the pilot wouldn't light and I had to replace the thermocouple which has to be a Polama part, a universal won't work, then replaced the pilot tube and burner. Then it would fire and run but not long. So I noticed the clear tubes going out into the bay had big air pockets. So I hooked up a swimming pool pump in a bucket and filled it with antifreeze, connected it to the system and put my drain hose from the system into the bucket and got all the air out. So then it still wouldn't fire. So I jumped the safety switches on the gas valve and still nothing. Paloma's website has a troubleshooting part that says I need to rebuild the water valve. Rebuild kit is $65. Long story short I am sick of the Paloma and can get a cheap tankless water heater on ebay for less than $300. Is this a smart thing to do? Will it do what it needs? What do I need to look for as far as specs? It will only be heating the truck bay floor. Thanks in advance.
