Appreciate any insight here. The solenoid for my tire cleaner in my SS keeps getting stuck open, so then the Flojet pump continues to run even after the bay turns off. I can disconnect power to the solenoid and the Flojet still runs. I take off the valves, clean out the plungers, rinse the manifold and it seems to work correctly for a week or so. Then gets stuck open again. I replaced the manifold block and solenoids, emptied and cleaned the hydrominder tank, took all the lines and fittings from the hydrominder tank to the solenoid off, rinsed them and replaced, but it continues to happen. Also it is mainly just on one station in a double bay. Any thoughts? Thanks again.
