Green_As_a_Gourd
I had a Parker C400B check valve fail open which let the high pressure get back to and destroy my FLOJET pump on my tire cleaner. I replaced the pump and check valve and everything was working. A few days later the tire cleaner in just one bay (the one with the new check valve) would not work. I pulled the water line going to the check valve and it started pumping again so I replaced the new check with another new check valve. Again it worked. A couple days later the tire cleaner wouldn't work again.
This was the second brand new check valve that I installed. I turned the tire cleaner on and nothing happened....I tapped on the check valve and it started to flow so I know there is some type of issue with the valve but 2 brand new valves failing so quickly seems suspect. I am using a G573215D FLOJET supplied with about 50 psi. The crack pressure on the C400B according to Parker is 5 psi. I have yet another new check valve coming tomorrow but I'm interested in anyone's input on what I am seeing. I am only 5 months in so this is all new to me. Thanks in advance for any advice.
