I have a number of clients that use flash dry.
The method requires placing air producers directly after the spot-free rinse applicator.
By stripping excess water immediately from the vehicle's surface as it is being applied, a virtual drip space is created.
The result is water rolls up on itself like a wave and gathers up the remaining water producing a dryer vehicle and using a lot less space than conventional method.
Generally speaking, the distance between rinse arch and dryer nozzle is about three feet.
Looking at schematic, positioning of producers resembles a V or diamond shape.
For example, one of my clients has 40’ mini-tunnel. The dryer configuration has three rows.
First row has one 15 hp producer positioned 3’ from rinse arch, followed by a row with four 15’ hp producers, followed by a row with one 15’ hp producer.
I was sold on this method about 7 or 8 years ago when Vince MacNeil and his chief engineer flew to Kansas to show us how to set this up for mini-tunnel, one of the first of its kind.
I can not tell from the video for sure, it looks like your nozzle is aimed towards the exit of the wash. I tried this for a couple days then went back. I personally would flip the nozzle so it would blow water up and over the windshield.
Your a mind reader! I was thinking that yesterday. I'm also considering the round nozzle but I'll try that first before the extra expense of $90 dollars.
Thank you
I see the intake faces the exit of the wash. Makes perfect sense. Makes for less moisture to get sucked into the blower. I always wondered why so many washes, including mine have the intake facing the entrance??
Note, I was referring to the inlet. Not nozzle direction.Earl, this is new to me but I'm giving it a chance. I like the original position of the nozzle facing the exit rather than the exit as well.
My equipment guys say if the motor faces the entrance it sucks in moisture and they have failures in 6 mos to a year even with motors supposedly built for this. Please get back to us in a year and let us know.
Okay will do!
