I am just curious to see, what you guys favorite drying agent is. I am currently using FC3 and I want to see if there is anything out there worth me testing. I do have Hot Wax which is excellent as well.
Nozzles - 2 on top 65/05 . 2 on each side 80/05 Applied with flo jet.
Dilute product 10 gal water to 5 gal product. Usually 20 water / 10 product at a time and use a purple tip. I mix some hot water with the cold feed to the hydrominder - Seems to work better. Setting arch is cold.
Benny2, I have not tried FC3 yet. The reason I switched from Bead Up to Super Dri was using the same amount if drying agent I was able to get an equally dry car. Super Dri is cheaper per 55 gal drum than Bead Up. How much are you paying for FC3 for a 55 gal drum?
I'm not exactly sure off the top of my head but I believe about $640. What are you running the bead up on and what ratio, I think I will buy a 5 gallon and just try it
