Extrutech in IBA
bert79
West Michigan
We installed a used laser 4000 about 3 years ago. We put up new white pebbled frp in before installing the lw4000. Now we are looking to upgrade to a new Razor to replace our aging machine. I need your opinions. We are considering installing extrutech as we do the reload. My thoughts there are that we should do it now because if we dont we will end up with holes in the frp when they install pieces in different spot (mainly conduit, sensors and junction boxes. I would also like to consider installing extrutech onto the ceiling of the IBA (it is painted wood joists). The bay is not big (25' x 16' x 12" approx). Any thoughts on this. I'm most interested in hearing from those that have faced a similar decision. If you care to share your costs of material and labor i would be interested in that too. Thanks!
Car_Wash_Guy
out west
I have 2 sites a 4/2 and a tunnel. My 4/2 had them already installed and the tunnel was block and I installed the panels. Went faster than I thought it would and looks 100x better. I know from my 4/2 that its easy to clean and looks great when clean.
110' tunnel cost me $6K in panels shipped but the prices have gone up substantially.
The good news is you can get some stunning results with it. I Priced out doing some bays and found the install cost high. To do it right I had to use stainless oval head anchors.
Car_Wash_Guy
out west
I use the tap con like anchors that they supplied me. Used a cordless rotary hammer and impact driver to screw the wall.
Panels plus labor came out cheaper than the estimate I was getting to spray epoxy.
I think the stainless anchors are overkill .
What are stainless oval head anchors? The install manual recommends a 3/16" by 1 1/4" flat head Tapcon with a 1/4" stainless washer under it. Hopefully Tapcons have improved because I have snapped off tons of 3/16 diameter ones over the years before they would even draw down.
I see that they also recommend those all nylon nail-in anchors for masonry. Has anyone used that method? We have used them for signs but sometimes the nail/pin breaks off before fully driving it in or if not careful the head cracks if you overdrive a tad. It seems that we had better luck with one brand but of course I can't remember what it was.
If the nail is breaking off before it drives in, the hole is too small. Masonry bits aren't precise and different brands will cut a different size hole - they can even vary within a brand if the carbide tip isn't perfectly centered. Also the tip will wear down and the holes will be undersized.
Could be it. Next time I'll pay closer attention to hole size.
HeyVern
Same applies if your falcons are snapping off, use a slightly bigger bit
I used a Ramset T3SS gas gun and a MO34BB pin to put up extrutech panels at my wash fifteen years ago. You have to do it when warm, the panels are brittle when they're cold and the little mounting strips will crack. No holes to drill. It was a huge time saver. You can put five pins in a panel in less than a minute. It was so convenient I installed the extructech by myself in an IBA bay a few panels at a time. I told the extrutech rep about it many years ago and they weren't really interested.
Greg, u do that directly into the concrete?
tdlconceptsllc
NC
They make stainless Tapcon screws also if y'all worried about rust I have used them on bay signage.
I recently found that out but it looks like they do not make the short 1 1/4" screws in stainless and the longer ones are not threaded all the way to the head.
throw those away, use an actual masonry bit and root hammer
The ones that come with them are a straight shanked masonry bit. I also have both a Bosch SDS Plus and Bosch SDS Max rotary hammers. They are corded so if I'm just putting in a few holes I tend to use the 18v cordless hammer drill with the straight shank bit. I have had issues with the 3/16 screws breaking off many times when drilling the holes with the German made Bosch SDS Plus bits also. It has been a while since I was using a lot of 3/16" screws but I'm guessing now I would break off one in every 30-40 in concrete or even standard block. Many times it is difficult to put another in somewhere else after breaking one. These days I try to make my project conform around using the 1/4" screws with the hex drive heads and can't remember breaking any of those off.
FWIW I've had issues with Bosch bits drilling undersized holes, even with 3/8" and 1/2". I buy good wedge anchors from a bolt supply (The Home Depot brand are great about spinning in the hole and never tightening up) and sometimes I can't get the anchor in the hole without a LOT of pounding.
tdlconceptsllc
NC
Our town here you go would work perfect for panels I have used them screw all the way down tight. Confast is where I buy all my bolt from there service is superb.
I was just looking at the Tapcon brand and did not look at others. Fairly pricey but a good option for car washes. Have you snapped any?
Can you get those screws in a shorter length?
