Electric apron heat?
I wonder what the operating costs would be on that system and how long it would last?
I wonder how big of a solar panel - wind turbine with battery would generate enough electricity to avoid the kW to BTU cost??? You would not need a circulating pump & antifreeze. Maybe for small areas with less sq footage???
Electric driveway de icers are usually in place to provide deicing when there is precipitation. Running 24/7 for weeks or months is too costly for a SS and 15 hours a day for a tunnel compared to hydroponic.
PaulLovesJamie
rural 5 bay SS
Kutztown PA
Electric resistance is the easiest to install, but the most expensive to operate. I have a simplistic spreadsheet somewhere that shows the exact difference in operating costs among fuels ... (did that quick analysis when I built my house 20 years ago and needed to know if I could cost justify a geothermal heat pump). Iirc the difference between electric resistance and natural gas was about triple. Pretty sure it is worse today, meaning that electricity has gone up in price at a faster rate than natural gas.
If you want to actually calculate the cost difference let me know, I might be able to find the spreadsheet.
check your pm's
Some geographical climates like here in ND ... it snows even at way below 0°F. That also would be a factor for using it like Earl made note of.
John J Spokas
Naperville, IL
I have installed these with moisture sensors. The advantages I see with electric vs. boiler w/anti-freeze:
1) Much easier install.
2) Less space needed for equipment.
3) Easier to set up controls.
4) Fewer components to wear out.
I don't know what the difference in operating costs is, I will be very curious about that if I ever do another.
