MEP, I had to replace the dema valve to the power blast. The latest issue is the side spinners on passenger side will not spin on, which is very strange, the return to rear on high pressure. it turns on every other pass, even high pressure forward. Very strange. I replaced the bottom side spinner swivel with no luck. I do have the link belt pretty tight. Any thoughts?
Get rid of your belts and bearings and replace with water drive swivels. You would have to add medium pressure spot free to your pumpstand using the soft start valve
