dgunderson
I've been working with an Istobal M22 with profiling dryers. Mysteriously, the dryer has lowered itself to the bottom stops twice, we have it on video. On one occasion the raise/lower motor continued to run even after the blower met the bottom proximity switch. This caused the belts to wrap around the pulleys backwards. Unraveling that mess was no small trick. I have some theories; someone butt dialed the machine on their cell phone and lowered the dryer or someone with remote access lowered it intentionally to piss off the owner, but that doesn't explain the belts unraveling, the prox should have stopped the motor. Next possibility is that the computer has a glitch either in the hardware or the software, but again there is the belt issue and the fact that it apparently did not acknowledge the bottom proximity switch. Finally, there is the possibility that the VFD did it, if it operated independently from the computer that could have explained the belts and the prox. Right now I have the computer inputs to the VFD disconnected and we are running without profiling. Istobal is stumped. Anybody else out the seen anything like this?
