D&S 5000 Owners
rph9168
Carwashguy
Atlanta
Most of the so-called major brands should do the trick. Check out your local suppliers and see who gives you the best service and keeps your cost per car in line. You may have to look at several before getting the performance and cost you want.
Red Baron
Idalou, texas (near Lubbock)
I am using Warsaw Chemicals in my D&S 5000:
534 Wonder Soap
536
530 Triple Foam
Weather Shield.
I'm very happy with my results. Recently switched from Berry Dry 570 to the Weather Shield, and the added gloss is noticeable.
Red, try replacing wonder plus with their new "finisher". It is essentially wonder plus with more alkalinity. Just a few dollars more than wonder.
534 Wonder Soap
536
530 Triple Foam
Weather Shield.
bruno
I used to use wonder plus, I switched to finisher about a year ago and have noticed that the finisher is dulling my chrome trim and can't be repaired. I never had this problem till I started using finisher. Took about 6 months to show up.
bruno
Does blendco cost more than warsaw. I was happy with wonder plus. Still haven't found a pre soak that will gets the window eye browl.
Gabriel
The answer is to shop, try the products and you will find what works best for you at the price that you are willing to pay for the results that you want. Most companies will let you sample their products.
dogwasher
Red, I have a DS and on the single pass it dosnt clean so well in the summer weather. Do you use a single pass and if so how well do you clean?
Thanks for any help
Grand Poobah
Powder made easy
Works great. I use it on two 5000's. It is made by Stone Soap, great company.
aca carwash 2
Maryland
I used to use the warsaw presoak and it did a good job.....I switched to the armour all
two step presoak two years ago,no comparison...100% better
Flash
Flash
Rapid City, SD
best presoak
I have a new D&S 5000 as of last july. I couldn't get it to clean. I started useing a presoak called (FIRE WASH frictionless presoak), from Stone Soap Co. Then for my 2/step I use Kemade B also by Stone Soaps. The fire wash is a liquid as it is better than the powder. I also went to 112 degree hot water max. It flat cleans now.
