Customer racks up free time w/dixmor timer and royary switch
Ric
Cantree Member
West Michigan
I have Dixmor LED7 timers and 8 position rotary switches.
We are in the equipment room and hear a bay being switched from one selection to the next very quickly. We go investigate. The kid says if you switch it fast you can rack up time. It took a bit of messing with but sure enough I was able to add time just as though an additional coin was added by ratcheting the rotary switch randomly.
Has anyone experienced this?
That's a new one on me, I've never hread of that. I'll have to try that next time I go to the wash.
I've actually seen that happen, but not with a Dixmor. If it only works with the timer running, try installing a relay on the timer output to isolate it from the switch.
Tell the kid that it's felony theft of service; he probably won't do it again.
Had the problem not long ago. My guy fixed it. I think it was a bad switch taht we replaced I will check with him. There was some sort of short sending a pulse back to the timer.
bigleo48
Ric,
I'd just kick the crap out of the kid ;) Then fix the problem!
I tried it this morning at my wash and it didn't work, tried it in all the bays. I think you might have a bad rotary switch or a wiring problem.
JIMT
Toledo, Oh.
Ric,
I had this problem years ago and it was the Gin San coin acceptors that created the problem.
Jimt
coincarwash.ca
Washin cars in the GTA
Toronto, Canada
Check to see if your last minute alert horn screws are tight.
I had the same problem and the vibration was causing a short in the loose connection and adding time to the timer...I tightned the connection and fixed the problem.
