Cryptopay push button
C-Ray
My cryptopay push button is requiring several pushes to stop. Where can I buy a replacement button?
If it is the newer 16 mm diameter button then search for this:
PV6H240SS-331
You can get them at many places on the internet. You will have to solder 4 24 gauge wires on it, break the seal on the swiper case, reuse the button retaining nut (the corners are ground off) and re-seal the case with silicone caulk.
C-Ray
PV6H240SS-331
Thanks for all the help!!!
AutoSpaMobMO
Moberly Missouri
PV6H240SS-331
Glad I ran across this post. I just started having this issue.
Thank you!
