Converting IDX Timer to Dixmor LED 9
APW
South
I have converted a 20 year old Fragramatics shampoo/vac to a LED 9. Everything is working fine but when you flip the toggle to shampoo the time stays the same. Is there a way to set a different time when shampoo is selected?
APW
South
I got the multi function one.
You can have 6 different prices per minute and start dollar amounts with that model if you wired it with the separate outputs. Did it come with the instructions?
I just looked at my instructions and it has 6 different inputs not outputs. The only output would be to the rotary switch or relay.
Not that I know of. You could probably do it with an LED6 "sooper" timer. I've been meaning to try that.
I attempted to do that - the LED6S will require you to replace the toggle switches with pushbuttons. The function won't change until the selection contact is closed and then opened.
