Converting IDX Timer to Dixmor LED 9
APW
I have converted a 20 year old Fragramatics shampoo/vac to a LED 9. Everything is working fine but when you flip the toggle to shampoo the time stays the same. Is there a way to set a different time when shampoo is selected?
You can have 6 different prices per minute and start dollar amounts with that model if you wired it with the separate outputs. Did it come with the instructions?
I just looked at my instructions and it has 6 different inputs not outputs. The only output would be to the rotary switch or relay.
