I have a bay that has a continuous spray. Troubleshooting I have changed the Erie 3-way valve this worked for a day it started again. I then replaced valve and seals on cat pump, balance pressure regulator- replaced hose & fittings from Erie valve to 310 cat pump worked for 1 day. I then replaced 3 more fittings- redid 2 other hose fittings- replaced spot free check valve- Erie 3-way check valve & replace wand assembly. This worked for 2 1/2 days. Then replaced 310 cat pump and assorted fittings, this worked 1 day. Now it is keeping a continuous spray of 200 PSI- I rook apart the new balance pressure regulator and wiped and grease it with plumbers silicone grease-no change still spraying. any suggestions would be appreciated.
