Colored tips for Injectors
steve569
Olathe KS
I run a Washworld Automatic and was wondering if anyone knew where you could buy tips for the chemical injectors of a particular color instead of having to buy the whole package that comes with all the different colors?
PEI
Danville, VA
You should be able to order a specific color of tip from either your chemical supplier or your Wash World distributor. Usually, you have to buy them in large quantity packs. We can order them from Carolina Pride, but unless you are using a lot of one color it is cheaper to buy the mixed pack.
Take the extra tips you have with a smaller hole and have them drilled out with the correct size bit to match what you want. Many times the package of tips will have the drill size index used for each color so you can match it to your needs.
