Rebuilding my first wash and am having a bit of trouble with the cold water inlet. I have the cold water set down to 20 psi going through a normally closed solenoid and the hot water is gravity fed and open. Way I have it set is:
soap ------------/ ---------soap solenoid---------neutral
wax-------------/ -----coil----------------------neutral
|____Normally open --cold water solenoid---neut.
rinse-----------/ --------------Normally closed----cold water solenoid--neut.
|_____Normally open ----wax solenoid----neutral
so a DPDT with the coil activated by wax
So is this set right? I am seeing some weird behavior when I have the soap on in a bay I get a totally different function all lighting up. Could that be a symptom of the above or do I have a short somewhere? Any help is appreciated. I have been struggling with this for about 3 days. Thanks
Russ
Russ
