carwashspain
- Joined
- Oct 12, 2019
- Messages
- 15
- Reaction score
- 3
- Points
- 3
So I had a weird thing where two problems happened simultaneously and I’m wondering if they’re connected. The first one is fixed- tire and engine cleaner was on constantly and I couldn’t switch it off. This was a relatively easy fix where the solenoid wasn’t activating properly, so I just replaced it. However, then I noticed this other problem that wasn’t there before the solenoid problem, where the lcd display in the bay says ‘0’, you put a dollar in expecting it to change to ‘1:20’ (1 minute 20 secs) and it does nothing. Tokens don’t work either. The coin mech is fine, light is green. My electrician had a brief look at it and he couldn’t see anything obvious. It feels like a lose wire type of problem, but all the wires look ok. He’s thinking it could be a problem with the circuit board for the bay, but it’s just weird that it happened at the same time as the solenoid problem (although that was in the plant room) so I’m wondering if they could be connected?
