I have a self serve bay that regularly jams up, running a microcoin accepter and I've switched it out with another with no improvement. I'm wondering if a worn out face plate coin slot could contribute to jams?
Where exactly is it jamming up? We have seen old faceplates cause jamming issues, especially if a previous jam has damaged or changed the coin path even slightly.
Over the years, I've had issues as well. The plastic tabs that hold the unit together wear out over time or break. Also, check if your panel has a slightly negative tilt inward. I've found that a little gravity helps. As always, clean them regularly.
If your meter doors are anything like mine, check for wires getting in the way of where the coins drop or roll. We have to watch as we shut the doors.
I hope it's that easy.
