Cleaning d&s quicksilver
dax_festival
Iowa
Does anyone use a cleaning chemical that works exceptionally well on the quicksilver shroud? I've only used acid (almost no dilution) & it just doesn't seem to get everything off. I'd like to experiment with other thing & seeing what y'all have tried
tobaccofarmer
The best product for cleaning machine and bay walls is at home depot made by ZEP called calcium lime rust remover, its a knock off to CLR only cost 9.97 gallon is 5 times stronger than CLR and works great , dont dilute just pour into sprayer and spray directly on whatever you are cleaning, then brush then rinse. If you want it even stronger add some muratic acid (pool acid) and it boosts it even more, usually not needed but I have done this before.
