Chemical tire applicator using a tape switch
Ric
Cantree Member
West Michigan
Any recommendations for a cta unit and a treadle/tape switch for a conveyor tunnel wash?
Made my own. Standard Tape Switch. Standard Pumping (With air injection like a foamer would have) station activated by 110 Volt Solenoid. USed a Vacuum Timer. Ran Tape Swithc leads to coin Pulse. Set for 2 seconds per coin. Ran 100 Volt out leads to solenoid for air for flo Jet.
Used schedule 80 PVC for application Mounted to strut on first arch with PVC Check valve at each for the liquid line.
See
https://www.youtube.com/watch?v=yToxbXhNVZw
I've been thinking for some time about making one and combining it with a programmable relay. My thought was to use several switches and sets of nozzles and have only a short blast each time a switch is hit, and set up so a vehicle backing up won't trip it again.
Ric
Cantree Member
West Michigan
What length of a tape switch is needed to "catch" all vehicles in a tunnel?
30" will definitely do it. Since my floor is kind of rough I put it on top of a steel plate. Also a plate on either side so the car rides on an off smoothly.
getnbusy
United States
Nice setup Earl.
I am wondering could this be activated by a set of eyes ? I mean like some undercarriage eyes ?
TEEBOX
Detroit, MI
My tape switch i s 36 inches long. It is also in a steel plate that was cut into concrete. Level with the floor.
Nice setup Earl.
You could use eyes but they seem like a bother. Someone walks thru and it sprays. Have to run wire between them . Typically need a transformer. Must be high emough to clear rail but low enough so body mods don't break the beam.
