I like the Teflon Fluid controls as well. They will seal fine with higher pressures, however, sometimes at low pressures they will seep a little bit. The one and only problem I have with the Fluid Control check valves is that after time the screw will unscrew from the poppet which obviously results in a failure. We still use them quite a bit and I am considering using locktight before their intial installation.
