Bigmatthew86
Hey everyone, I’m catching hell in getting check valves to work for my application. They are 1/4 & are the valves that control the high pressure soap & wax entering the system on my old Futura setup. The ones the previous owner had on there were failing & starting to allow water to push back into my hydro tanks. I’m on my 3rd set. Problem I’m running into is that the soap system creates next to no pressure so the valves have to be very light. Too stiff & I get no push back but I also get no soap. I’m probably needing 1psi or less crack pressure but then be able to deal with very little push back pressure. This are the ones I’m running now & with my super scientific test (me blowing through) I can but it still seems it restricting my soap.
