So it's not the rotary switch. I've been digging for the problem but no luck.
- replace 2 check valves under the pump
- replace 2 sus fittings
- open/clean soap solenoid
- open the pump head, look through seals they all look good (didn't changed new seals)
- change pump's oil (still see some air bubbles on top)
From the start it runs great for good 3, 4 minutes. As switching to other options, go back to rinse,Wax, soap pressure drops. Turn to low pressure, then back to high pressure the weeping build pressure, but drop pressure as I squeeze the trigger. Pump runs great without shaking or starving BUT the pump head gets hot quick (looks like overworked). One thing I know it's somewhere out there air gets into the pump because air bubbles coming out when I open pump head's plug. So frustrating. Should I go ahead replace new head seals?
