madscientist
does anyone have a trick for getting the little piece of copper (that the wire connects to) out of the old brush body without detroying it? i'm batting about .250 lifetime.
+1Crush the old brush with a pair of pipe pliers or vise grips. The terminal will fall right out.
I have no doubt that if you do certain maintenance things will work like new.Man, I've changed brushes in my vacs a few times and they seem to come right back to 100% power/suction. Maybe I've just got 'the touch'.
Now that I've changed a number of motors out, I've implemented an annual brush change procedure on all motors that have been replaced, the rest I'll run until failure. My plan isn't about the cost-effectiveness of changing brushes vs. replacing motors, it's about minimizing the failure rate of the replacement motors. It's been my experience that the end-of-life of the brushes will usually take the motor out with them, and if I don't catch it right away I'll have dissatisfied customers.
Your point about reliability is well taken, and I know how to look at a hose and see if it's worn.
So the question is how do you look at a working vacuum with OK brushes and tell if it's time to change it because failure is near. Or, haven't you had any where you placed brushes these fail yet, or will you just change them every 2nd year if they last that long?
Long story short, I shuffled around some motors to have all the vacs with the same brand of motors in pairs, and I replaced the brushes in all the motors except the Lambs. As far as how to tell when they're bad, it's just a few bucks for the brushes and five minutes per vac to change them. If I'm changing them too early, then I'll be throwing away less-than-half-worn brushes. I have time to change the brushes once a year, but I'm not going to sweat trying to work out exactly how long I can go before I need to change them. Again it's like my bay hose procedure, the extra $100 or so a year I spend on replacing the hoses before they break give tremendous peace of mind as well as less downtime and no ****ed-off customers from burst hoses. Pick a common problem you deal with and figure out how much it would be worth to you to eliminate it.Earl Weiss said:So the question is how do you look at a working vacuum with OK brushes and tell if it's time to change it because failure is near. Or, haven't you had any where you placed brushes these fail yet, or will you just change them every 2nd year if they last that long?
