Change Arming Option With FX-20P
waterlogged
North Carolina
Does anyone know how to change the arming from Network to Alternate on a Ryko machine with the Mitsubishi FX-20P hand held programmer?
Ryko CS
Grimes, Ia
You will need to have an HPP with the Ryko program in the back of it. From your HPP, enter the following:
GO GO OTHER SET8 then use the down arrow buttons to get to the line that says "Machine Setups".
Press GO to get into the setup questions. The question you are looking for will vary by equipment and/or program. In some models and versions, there is a setup question for "OtherArming?" that would need to be answered "YES". In other programs, it may ask if you have a "CAW Option?" and also have a question for "Other Arming?". In this case, answer the CAW question no, and the Other Arming yes.
