Cat pump motor pulley
dawar15
hello there,
Can someone help me hope to take this pulley out .
hello there,
Take the 2 bolts out and put them in the bushing with the threaded holes and tighten the bolts. As you tighten the bolts they'll push the sheave off the bushing. Once you get it loose you'll see a groove in the bushing drive a screw driver into the bushing to open it up and it should come off. Sometimes you need to put a puller on it if it doesn't want to come off.
Thankyou so much
