SparklesSS
Hi all,
I have a Custom Craft setup that has been great with the exception of 1 bay. I have 1 bay that keeps acting up. The previous owner struggled with this bay for almost 3 years. Here it is:
Took over the wash a little over a month ago. Cat 5CP2120W started knocking a bit in the last week. Started getting worse to the point where the high pressure functions would not go past 900 psi and the pressure would fluctuate up and down with bad knock. Low pressure seemed to be fine. Walked into the pump room a few days back and when the weep would kick on the pump seals would drip water. I pulled the pump head and rebuilt it. I also took the solenoid valves off the block to see if there was any water obstruction and changed a check valve just to be safe.
Pump seems to be working fine now but the previous owner indicated he would rebuild the pump and it would work well for him for about 1-2 weeks before it would start acting up again. He has even changed to a new head in the last year and it lasted a bit but then started cavitating again.
Any idea what could be causing this? Is it lack of water flow?
Other 3 bays seem to be working fine with no issues.
