Cat 623 pump chugs
randall
When its running(handle is not depressed in bay)it chugs.
When the handle is pressed,it runs fine.
Things i've done~Replaced and tighten belt~Same issue
Replaced contactors in the NEMA motor starter.
What puzzles me,is when i disconnect the handle in the
bay it runs great(just the bay hose)...no problem
When i replace the handle(old or new) without the wand
it has the same issue(i've used the sw1500 weep handle
from kleen rite) Anybody ever have this problem.. i'm
stumpped...thanks
What does the gauge read with the trigge pulled/not pulled?
What exactly do you mean by "chugs?"
randall
Not sure about pressure reading...I'll look at theat today
As far as chuging..it stops and goes,instead of running smoothly
Greg
Outdoors
623 pump chugs
Hi Randall, Check the pressure regulator and replace if old or worn.
Your test in removing the weep spray handle indicates a probabililty that the regulator is not bypassing, or the bypass hose is restricted.
Greg Thoennes
Tech.Support
Arimitsu Pumps
