owinborne67
Got a real head scratcher for y'all - one of my Cat 530's is noisier than the others, and the pressure is inconsistent. Cat tech support said probably cavitation due to an intake or outflow restriction. Today I spent some time going over the piping, re-taping most of the intake, and along the way I noticed what the video shows - when I take off the cold water solenoid and force the pump to run off the backup tank, the cavitation gets a lot better and pressure improves. All of my other pumps are plumbed the same and none have this issue, though this pump is the busiest one.
There's no leaks in the piping on the cold water intake so I'm a little lost what could be causing this - already re-taped most of the joints on that side and replaced the diaphragm in the cold water intake. Figured before I keep tearing it down I should post here in case anyone has any ideas? Thanks!
