R Rainway Member Joined May 24, 2018 Messages 135 Reaction score 19 Points 18 Location Alaska Oct 21, 2020 #1 Anyone know a replacement part number the check valve coming out of CAT 3k133 pH pump - to keep the pump from kicking product back into the pump stand? Thank you. Last edited: Oct 22, 2020
MEP001 Well-known member Joined Aug 30, 2007 Messages 16,667 Reaction score 3,937 Points 113 Location Texas Oct 22, 2020 #2 Is this it? Steel Body 20 GPM Check Valve with PTFE | Fluid Controls CV-800T This Fluid Controls CV-800T check valve is constructed with stainless steel and has female 3/4" connections. Rated for 20 GPM and 3500 PSI. www.kleen-ritecorp.com SS 3/4 In. Check Valve Repair Kit PTFE | Fluid Controls RK-CV800T Repair kit for Fluid Controls CV-800T stainless steel 3/4" check valves with PTFE seals. www.kleen-ritecorp.com
G Greg Pack Wash Weenie Joined Sep 3, 2007 Messages 4,143 Reaction score 1,795 Points 113 Location Hoover, Alabama Oct 22, 2020 #3 Not sure what the difference is between the one MEP linked but I use this one: Stainless Steel Check Valve - 3/4 In FxF, 3500 PSI, 4 GPM, PTFE | Fluid Controls | CV-800T This Fluid Controls CV-800T check valve is made with stainless steel and has a PTFE O-Ring with female 3/4" connections. Rated for 4 GPM and 3500 PSI. www.kleen-ritecorp.com Coleman uses the SMC plastic one, but they crack at the threads over time: Black Poly Check Valve | 6870290 | Polypropylene Body Check Valve The SMC 6870290 Check Valve is made with chemical-resistant polypropylene and has maximum pressure rating of 125 PSI. 3/4" female NPT ports. www.kleen-ritecorp.com
MEP001 Well-known member Joined Aug 30, 2007 Messages 16,667 Reaction score 3,937 Points 113 Location Texas Oct 22, 2020 #4 Greg Pack said: Not sure what the difference is between the one MEP linked but I use this one: Click to expand... I linked the Viton seal one, but the Teflon seal one you linked would be better.
