toddmullens
I have a bunch of old water wizards and seem to keep breaking valve springs on the cat 3535 pump. Anybody have any idea what could be causing this? Cat says it cavitation or excessive turbulence, put I am not sure where to look to find the cause of excessive turbulence. I am fairly confident its not from cavitation. I have no leaks on the inlet of the pump and have replaced the tubing for the wax and soap to hose that is crimped on to hose barbs. I have noticed when using the test functions, that whenever the rinse is turned off, the pump comes to an abrupt stop, but whenever I test the rocker panel function, it stops much smoother. Could the dema solenoids on the gantry for the side and top spray be the cause of the abrupt stopping? As far as I can recall, there is not an off delay on those solenoids to keep them open for a couple seconds after the pump turns off.
