CAT 310 problem
Jim64
TN
Had a cat 310 with low pressure. I put in a new seal kit and it ran at 1200psi for about 2 weeks. Now it runs at 1200 till you squeeze the handle then drops to 900. Head problem? I inspected the head for wash out issues and it looks OK. Pressure regulator looks OK but is old. Any suggestions before I tear open a new seal kit.
First thing I'd do is to swap out the pressure regulator with a known good regulator, like from another working bay and see if the problem goes with the regulator.
Jim64
TN
Thanks Randy, I Replaced the pressure regulator but it did not correct the problem.
Now that you've done the easy fix it's time to move to the valves. Pull the valves out looking the "O" ring and the white "O" ring retainer, any debris under the valve disc. Also check the valve sitting surface for erosion, wash out. If everything looks good on the valves you've probably got a head problem.
Before you throw any more parts at it...
Have you replaced the tip?
Does any water come out of any other bays with the problem bay running?
Does the pump run smooth all the time? Does it run smooth with the trigger released but pulsate with it pulled?
Is the pressure low on all functions, or it it low on soap but fine on rinse?
Jim64
TN
I checked all the valves before I changed the regulator. The tip is about a month old. Pulsates a little on both. Haven’t checked to see if it’s bleeding back, I’ll do that tonight.
Pulsating could mean an issue with the valves/o-rings. You should probably go there next.
Or restricted water flow to the pump?
Jim64
TN
No backfeed, all the valves are good. The pulsating is very slight. Probably only a Carwash guy could notice it. I think it is in the head but I inspected for washout. Carwash pumps are like kids, they all have different personalities.
I'm kind of thinking you might have a head that's starting to or washed out. I'd probably pull it apart and take a long hard look at it. Look at the high pressure seal for any grooves along the side and on the sealing surface. Do you know what head wash out looks like?
Check both the seal area and the valve seat area. If the o-rings blow out in a short time, the manifold is probably washed out there. They can be resleeved. Be sure to check the valves for cracks or debris.
Jim64
TN
Thanks guys, gotta be the head. I thought cat would do a one time resleeve at no charge. If not then any idea what to expect on that cost?
Nope Cat won't resleeve a Cat 310 pump head. It'll cost you around $150 to have all 9 ports sleeved with stainless steel inserts. I like the way IDS does it by pressing the inserts into the head.
Jim64
TN
At that point the head should be same as new? Throw in another 75 for shipping and 80 for a new seal kit and it’s at $380. What’s a new one, around $600?
Send the head by US Priority mail, cost you $15.50. By doing the stainless steel inserts it should last forever. A new head from KR is $480.00.
Jim64
TN
Thanks Randy, i read their info on the link you sent. Do you do a swap or wait on your original head?
I have a number of Cat 310 pump heads I send one and get my original head back. It takes about 2 weeks. It pays to have a spare pump head.
Jram
