Carwash dial
joejim
I just replaced my dial on one of my selfserve bays. Now I have no equipment working or not working properly. Old1 in hamd new 1 installed. Did i put them on the wrong numbers??1000037722.jpg1000037855.jpgperly
Not sure if your switch is 8 position or 10 position. If it’s 8 position, due you have 11/21 jumped together? If it’s 10 position, due you have 10/20 jumped together? What exactly is it doing or not doing?
@tdlconceptsllc Thats good advice! I would also chech and make sure that each wire is only touching the one spot it is supposed too. If one of those spade conectors is touching more than one contact point, it can really mess stuff up. Detail is key on those things. Good luck.
Did you get the same brand and # of positions on the new switch as the old switch? If either are different, the configuration of the terminals maybe different also
