Bulkhead for HW Holding Tank?
Car_Wash_Guy
out west
I have the usual 1" black PVC ones. They usually start leaking after a while. Does anyone have a better solution? I've seen some stainless ones on Zoro and Grainer just wasn't sure if that's the way I should go?
cantbreak80
Maybe I need new clubs
CO
Maybe the problem is with the gasket material?
EPDM vs FPM
Where do they leak? It's pretty easy to split plastic fittings by overtightening or hanging too much weight off them.
Car_Wash_Guy
out west
Yeah this one cracked from me over tightening it. Do you guys use Teflon tape, dope, both or just one?
cantbreak80
CO
Spears Manufacturing offers this for their threaded connections:
"Use a quality grade of thread sealant approved for plastics, such as Spears Blue 75.
CAUTION: Some sealant compound chemicals may cause stress cracking. 1 to 2 turns beyond finger tight is generally sufficient for plastic threaded connections. Do not over tighten."
In the past I've used 2 to 3 wraps of Teflon tape and a light coat of silicone...with cure time being the downside.
Now I follow Spears suggestions I've had no real issues.
