Bought a used wash.
I'm not sure I follow you? What does the sight size have to do with the in bay automatic?
Think he meant small, as in small potential. Which is probably erroneous....
APW
South
20210724_153330.jpg Started putting wall panels in the self-serve but now the tile looks so dingy above. I wonder if paint will hold up since it won't get wet as much up there.
Know a giy in OkC who painted up high. Lasted pretty good forna # of years.
Did you drill directly into the brick, or put wood over brick & go into wood? What type screws you use?
MC3033
Midwest
Paint has held up for me in pretty much the same position on the same block, about 5yr in. Looks a bit darker now but likely just needs a power wash
  • Like
Reactions: APW
APW
South
I screwed it directly to the tile/block with tapcons that they sent.
APW
South
I wonder about paint adhering to tile though.
A latex exterior paint should stick pretty well to the tile as long as it's clean, and when it comes time to repaint it will scrape off easily.
  • Like
Reactions: APW
I wouldn't do anything to it until you are ready to cover it with some thing like extrutech.
Nobody's really going to look up there anyway, except you. Spend some money on things that are going to make your money instead.
Jealous of your Petit machine. If your up and running now please send a vid with that running. Did you quit your job?
