carwashspain
- Joined
- Oct 12, 2019
- Messages
- 15
- Reaction score
- 3
- Points
- 3
I’ve got no supersat or Presoak coming through to my spray arch. The double-headed injector in the plant room seems to be sucking ok, although both products are still struggling to get up the tubes. In the bay for about the last month there’s been a funny ‘rattlesnake’ sound whenever Presoak is activated. That’s now stopped and I’m just getting a mixture of just mist and water spray coming out. I’m thinking it’s either a bad check valve or a blocked foam generator. Most likely the generator, as if it was a Presoak check valve (for example) then presumably the supersat would still work, and vice versa. I’m just wondering if there’s an easy way to remove and clean the foam generator, as it seems pretty welded in there? Will attach a pic if I can.
