Best Coin Counter?
Scan con 303 is a good portable. Klopp also has a good name and is good with wet coins. As credit cards have become more and more used in this business the need for a coin counter is not what it once was.
How did you get an accurate gross revenue if you never counted your coins?
Cash deposited = gross revenue? Your hoppers only hold so much. Either you're buying coins to refill them or you're occasionally depositing a bag or quarters. It's not precise but it can't be far off on a large scale unless you have an employee skimming.
I counted coins from each device for a while, then realized that it was only data I was collecting for which I had no real use for and would not act on. Saved a bit of time in collecting.
On the original subject, I had a scancoin 303 I bought from IB many years ago and it finally gave up the ghost. I bought a Cassida about six months ago and it seems to work fine.
Before you get a coin counter - see if you need one. I recycled my coins thru the changer and never counted them.
Like Greg Pack said. . If I put $1000 in quarters in one time but only take out $900 in bills over time it evens out. Plus, the quarters were only one part of the revenue picture - Bays also took credit cards and paper $. Occasionally I monitored the Changer by using the hopper counters. Made sure if it dispensed 4000 quarters I pulled out$1000 in paper $.
That'll definitely get you in the ballpark, but not accurate enough for myself. I understand it's much easier and quicker to do it that way, but we have to separate coins anyways, so doesn't take much longer to count them
Thats the nice thing about cryptopay. No need for any coin counting. Hook up the two gray wires to your coin acceptor and get an accurate revenue down to the quarter. Nothing is more accurate and less time consuming than that for figuring gross revenue with coins and/or credit.
