On Friday I have my 4rth bent shaft; since posting in November. I should have it running again on Monday. I went to bold signage prohibiting long bed trucks. AS we know customers do not read. This past time it went 10 days before the shaft got bent.
I am still working on a solution. Each time it has been caused by an 8 foot bed pickup with 4
doors. Watching video, the arms are out, the brush is not turning. The arms retract but the passenger side one does not clear the rear of the truck. The gantry is moving and catches the brush and bends the shaft If the brush is turning it rounds the rear corner perfectly
I checked the brushes being level as suggested on the forum, Ok. I shifted to a high lubricity brush soap, I checked retract air pressure. The air cylinders & clevis and all hoses are in order. I cannot use more air pressure because the brush arms slam on the stops.
I started talking with Ryko factory tech support and my regional tech support manager. All are good guys. We started talking in November. The latest thought is that the return speed on the gantry is too fast. Unfortunately, because of COVID and schedules they have been unable yet to get a tech out.
Even though we do the shaft change in house, it is still expensive. A shaft plus a bearing plus several hours of my manager's time. More importantly my almost new Softgloss has acquired a bad local reputation for being down. Each bent shaft causes from 3 to 5 days of lost income. My new machine is broken down more than the machine it replaced
