Bay safe….
Troublesome5000
My self serve car wash has a square box safe at the bottom of the bay.. I can pull it in and out , but it will not lock… The lock is not catching in the back of it.. Do anyone know how I can fix this problem? Or know a company that do that type of work…..
Look in the back of the housing in the wall. Is there a threaded female fitting welded to the back wall or is there supposed to be some sort of nut that is held into something.
Troublesome5000
Thank you for posting , there is nothing in the back for the male end to go into... What can I do next????
It looks like the "T" handle lock has been drilled on. Can you open the lock and safe head and remove the box? If you can remove the safe coin box can you post a picture of the back of the box in the wall.
Do you have another bay that the T Handle does seem to screw in ? Can you open that and look in the back?
