Aquamizer 3000 Reclaim - any one service these?
sudsurfer
We have an Aquamizer 300 reclaim system that has sprung a leak in the resin tank.
We installed it three years ago and since then the company has gone out of business. We heard a rumor that someone around Atlanta was taking it over but we can not locate this person.
Anyone know of any body that can service or provide parts for this? We need to replace or repair a resin tank.
Google resin repair....this is something that is not too hard to do your self. You can order on line or maybe even find material locally near your. I had to do this to a grinder pump tank a couple of years back.
Replacing the tank is the easy part. You just need to measure the diameter and height of the tank, along with the opening at the top. It should either be 2-1/2 or 4 inches. It will be easier if you replace all of the resin. There will be about 6" of gravel on the bottom and then resin about 2/3 of the way up. You should be able to buy everything for 4 to 5 hundred. You will need to reuse the distributor tube that is connected to the head and goes to the bottom of the tank.
