Anyone have older version led6 dixmor for sale?
LED6 Version 1.2 can be directly wired to Nayax...Pulse wire 1 to LED6 Pin8 (white/black).
The current version LED6 needs a 5vDC optocoupler to provide the interface because Nayax’s output is 5vDC.
For Count-Up operation the LED6 Pin 8 needs constant 24vAC COMMON to activate the timer’s timed output.
Coin box 24vAC COMMON is wired to the optocoupler’s relay common terminal and the relay’s normally open terminal is connected to LED6’s white/black wire.
BTW…The same optocoupler can be used for Count-Down operation but the relay is wired differently.
HiLetgo 5vdc Optocoupler
Great explanation. I always tell people that with the optocoupler relay, you can make a Nayax or Monex do whatever you need it to do. Just make sure that the high/low jumper is on low.
