any recommendations for a unloader?
Scott.Downey
anyone have a favorite bulletproof unloader for a cat 5cp2140?
You don't need an unloader unless you're using shutoff guns. With a weep gun you want a balanced pressure regulator. Try the SMC 555 series 2000-2000 PSI range.
I've had good luck with a J.E Adams 7085 flow thru balanced regulator.
TMoliver
I prefer the Giant 22911 up to 13gpm up and 1400 psi, if more pressure is needed the then the 22913 up to 3000psi . A little pricier but they work for years and are rebuildable
